rn79870 »
https://forums.nicoclub.com/rn79870-u82084.html
Thu Feb 21, 2008 4:25 am
After the new plugs, and maintenance items, try looking at the EGR pintle.The pintle in pintle type EGR valves doesn't seat as well after many miles. If the G has a pintle type valve, take it off and clean the pintel and the seat.The valve is suppose to be closed during idle, but if it is dirty it doesn't close completely. A rough idle results. Check with infiniti to see if this is user serviceable, as it is something that, if done improperly, could result in error codes. (I have never taken the cover off my engine, or I could tell you more)
