Hmm... also how many miles? any upgrades (ie: air intake, fuel pump)... did this just develop? Is this car a DD (daily driver = DD).Eikon wrote:When is the last time you did a little tune up? Replace your spark plugs, air filter, fuel filter, etc...
Speaking of fuel pump, should I just replace anyway since it's been running for the last 13 years(140k)? Will I see the difference? I know Walbro is the way to go but heard that it's noisy. I wonder what other quality ones available out there and when is good time to replace it. Any thoughts?GoinTopless240 wrote:
The fuel pump also has a strainer that can clog... making the fuel pump work harder...if the pump has some miles it can get a little weak... When you come to a light it might sputter. I had a similar problem and after replacing the fuel pump and strainer the problem went away and the vehicle ran much better.... Eikon brings up the basics... always go the basic way first before diving in deeper. Plug wires etc.... You should be able to find a MAF sensor for dirt with many of us doing swaps we always have parts laying around...
Hope this helps.... and
Welcome to the Vert Boards... if you haven't registered on the sticky at the top of the topics, put your baby on the list.... it helps us determine how many Verts are still on the road...
Bosch sells the gasket, also. Maybe Nissan gets it from them?GoinTopless240 wrote:make sure you replace the gasket (dealer only part) around the top of pump assembly..
Whatever you do, always go from cheap to expensive parts.TuRbOS13 wrote:I'm actually having the same problem right now! When i'm stopped at a red light the idle will drop down really low, sometimes to around 300 and the car actually shuts off sometimes the idle gets so low. When I step on the gas I have no problems.........I took it to my friend who is a Master Tach and is a 240 specialist so he took apart my MAF sensor and said he's 90% sure its that.......he said I could get one for $30 used.
