rough idle, running rich
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok i have a 91 240sx with the redtop SR motor in it. I just finished the swap a couple of months ago and havent really driven it to much because of this problem. when i do drive it it runs fine until it warms up then the crazy idleing begines. Also when driving it, it stutters on light acceleration. while it is idling like **** it just clouds black smoke out the back. I did search on here and am thinking it has to do with either my MAFS, my o2, or my TPS. My o2 is brand new but is from a blacktop because stock wouldnt fit my turbo outlet. My TPS reads 4.045 volts at WOT, and i belive it is supposed to be at 4.5 not sure if this is a problem or not. I do have my BOV recircualted and i have checked multiple times for boost and vac leaks. oh and my vac gauge when it is idleing is only at 10, when it should be at 20.. I know i just wrote alot but your help would be appreciated. thanks
I check the ECU for codes as well i got code 55 which i believe is running normal so im guessing its the o2 sensor or MAFS... how do i test the mafs?
Modified by nissans13240sx at 2:41 PM 10/13/2006
da40
Car: 1995 SE 240sx
try running the bov normaly instead of recirculated
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
i did have it venting instead of recirculating... a lot of ppl told me that it will run rich if its not circulated thats why i went back to having it circulated. thanks for the suggestion though.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
bump... anyone?
Blown240sx
Car: 1996 240sx
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
thats what i was thinking. Do you think i gotta use the stock o2?? thanks for the reply
wildacexxx
Car: 2002 Q45 nav sport
its not your o2. its your water temp sensor. the one that goes to the ecu not the small one that goes to your cluster. my friend had that problem too. when car warms up it ran crappy.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok, wouldnt a coolent temp sensor throw a code though??? And where is this sensor located at, How do i test it? thanks for the suggestion
skillzilla
Most sensors like that wont throw a code. Ive had bad knock sensors that didnt even throw codes.
Sounds like a temp sensor to me as well, or an O2 possibly. Both would make it run rich once it was warmed up.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok so where is the temp sensor at? right by the thermostate housing? And is this sensor the same as the US sr20de sensor,... if not where can i get one at? thanks
masterteque
Car: 1993 s13 convertible 1993 s13 coupe
This problem is most likely the temp sensor like everyone else has already said. It is usually a red plug connector that is located kinda near the throttle body. If you straight on at the throttle body you'll see it. It is below it off to the right. You can get a replacement from the Nissan dealer and order it for a 91-94 SE-R. The new one will probably be a blue connector but that is o.k. If that doesn't fix it, I would go after the O2 sensor. You can check this with a multimeter if you have one....If you need to replace that order it for a 1988 Nissan 300zx turbo car. The connector will need to be repinned but it is very easy...Let me know if you need me to tell you how to check the O2....
Cyberkreig
Car: 1993 Nissan 240SX SR
nissans13240sx wrote:rough idle, running rich
yup. You definatly own an sr20.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Haha tell me about it... I know that the o2 sensor itself is good because its brand new. I am using a 95 TT 300zx sensor same as the blacktop sensor.... I am thinking this maybe the problem becuase they are 2 differnt kinds of sensors. I have the stock sensor but i need to get an adapter to make it fit in my turbo outlet. im going to replace the coolant temp sensor though to probably. wouldnt a bad coolant temp sensor give me a false reading on the gauge though??? My gauge works fine. thanks for the replys
masterteque
Your gauge sensor and your ect sensor are two different sensors. The problem with ect sensor is that is telling the ecu the wrong input. What happens is when the car is warmed up the sensor is telling the ecu it is cold. This in turn makes it too rich. This especially affects the vehicle when sitting at idle because it really loads up the car with fuel. You then take off and it runs like ****....I am pretty sure the O2 sensor you are using is wrong also.....!988 300zx....It should be like $100 from the dealer
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
oh see... I was told the 95 TT was the same as the blacktop o2 sensor... but never the less im switching it back to the stock one. i just got the coolant temp sensor. we actually had one in stock at the dealership i work at, so i will be putting that in today most likely.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok i replaced the coolant temp sensor... wasnt the problem, it runs good at cold idle as soon as it warms up the black smoke starts. So im almost positive its the o2 sensor now because until it is heated up its in open loop. and when it heats up switches to closed loop it starts running rich. its not getting the right signal im guessing. If anyone wants to corrct me please do, but for not im going to try that.
oki_bum
Car: SR Powered 1990 240SX
If your looking for a blacktop O2, the 1987 200sx 1.8L Turbo model one would work. Bought a Bosch one from autozone for $60 or less...
masterteque
Like I had said before, you will need to buy an O2 sensor for a 1988 300zx turbo model......
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok but arent the o2 sensors 2 differnt types redtop and blacktop. what i did was i spent 15 bucks and got an adapter for my redtop o2 sensor from megan racing. so i hope that works.
