..or bad Coolant Temp Sensor, or faulty AAC, or corroded connectors which I would check first as these engines are really prone to poor connections and then they don't run correctly.blackz32 wrote:sounds like injectors. i had the same rough idle
Usually when the engine is cold and it's on hi-idle it masks the issue.
Take the time to check the connectors for corrosion and test the components including injectors while the connectors are off.
Cheez-it it hasn't logged in since the forum changeover about 2 years ago. Doubt he'll see this. Also, this is what a private message was designed for. I know you're new and only have 1 post, but you only need 10 posts to be removed from the new users category and use the PM system. Don't bump a 3 year old thread just because someone you know posted in it at one point without adding anything to the conversation, please.werdgo wrote:you still have your z cheez it?
