JeromeS13 wrote:Seams to me that you just need to use better gas. Problem solved.
The real qustion is, why would you need to run higher octane gas...
Back when my car was stock and ran good I could run 87 with it idling good. No prob. Bogged alot, but it still idled.
Maybe a dirt idle control valve or a bad tps connection, missing throttle dog idle adjusting screw, or a bad injector (like my car is now) or bad/loose MAF or CTS.....etc.
or.........if you've advanced your timing....could be alot of it.
especially if you need a tune up. How long since new plugs, wires, cap, rotor, fuel filter, air filter??
Basically, anything in idle control wise or iginition or fuel wise can cause a bad idle.
Sooo.............pretty much any part of the car except the actual motor itself could be bad or loose and causing this problem, get an ohm meter and test all your sensors, if you've never done a real tune up, for the love of Nissan do it already.
