ROUGH IDLE LACK OF POWER
fatboybell
Car: 1992 Infiniti q45
Hello, I have been chasing a rough idle problem forever now.I have good spark and good compression to all cylinders.When I started the job i thought I had found the problem with 1 injetor having 50 ohms resistance,and another being completely open.well over the past days I have replaced those 2 injectors.Suprisingly this made absolutely no difference.The car is very driveable but it shakes at idle and has no power until higher rpm's.It definitely seems like a single cylinder miss,and it also pops through the tailpipe like a burnt valve,but the compression is good.The only idea I have left is someone has put the timing chain on with a cam out of time,but that would not seem to give the kind of miss that I have.Please help me,if I have to take the upper plenum off again I think I will scream.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Did you check the MAF connector, especially whre the wires enter from the rear?
fatboybell
I checked and cleaned inside the connector,and cleaned the filament.It appeared someone had slightly turned the pins for a better connection.This made no difference , but I did not put a meter to it ,what should I see if I do?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Check the posts by Q45tech. I think the upper limit is around 4.4V at redline.
Doing a power balance by a senior tech at the dealer may save you a lot of time if there are multiple tcomponents malfunctioning.
