Guam180 »
https://forums.nicoclub.com/guam180-u105580.html
Wed Nov 19, 2008 5:16 am
Hello NICO,
This is my first post and I know I should post in the newbie thread. But my problem is complex and lengthy, so I decided to make a new post for myself.
I have an automatic 1991 240SX Fastback and according to Carfax I'm like the 5th owner of this car. Engine and transmission might have seen better days, since the last owner told me he has had to get both rebuilt/ repaired. I have yet to see either work orders.
Since I've owned the car, I've gotten a new starter, battery, plugs, wires, distributor cap and rotor, oil change, radiator flush and new freezer plug.
At the time I got the tune-up kit (plugs, wires, and distributor, etc.), car finally ran ok. It would blip on its own (drop rpm by just a 100 rpms) once in awhile. But it never sounded like it was going to stall. Not like before hand.
Now its starting to get cold here in NC. Temps are now regularly dipping into just above freezing. That was just yesterday and thats when it started happenning.
When I first start the car, it idles good. A little high (somewhere between 1500-2000 rpms), but it is a cold start, so nothing to worry about, right?Car runs ok to work (work is about 15 miles away so engine should be nice and warm). But right when I get to the office it jumps around from 300-1200 a few times before finally giving up.
Now on the way to work this morning, I did stop once at a store not even 5 minutes away from my office, and was in there for about that much time. It started just fine then as well. As I said before, as soon as I parked the car AT THE OFFICE, it did that little number. Also, in the first half of my commute, I did notice that it seemed I didn't have a fourth gear. I'll be cruising at 50 mph, and RPMs are at around 3000. Obviously, that's too high for cruising. When letting of the accelerator in this state, RPMS would just fall to just above 2000. It sounds like that's where its suppose to be though.
So oh-wise gurus of NICO, is going on with my engine??
I apoligize for the novel, but I want to be thorough, and show you guys that my problem is unique in reference to all the search results I've been looking at....
