Rough Idle, Hesitation, Popping Sound, Help????
Foreva180
I've finally put ca18det into my s13, but it doesn't run well at all =( First, as I've said in the title, the idle is rough, for some reason, the rev would go up to around 1100-1200 randomly but slowly. Second, Hesitation, when I try to drive the car, the car will not drive smoothly, it hesitates real badly, but the funnie thing is that If I step the accelerate pedal all the way down it'll drive a little better. I really don't know how to describe it, but I guess hesitation is the best word to describe it. When I try rev the engine while it's in idle and in neutral, it won't even rev smoothly. Oh yeah, when i drive i heard popping sound in the exhaust. Once, the car gets into boost, the car will run smoothly. can someone please help me??
USDM_OneVia
Car: Racing
Timing is off... check it.
Joe
Foreva180
checked timing, and it's fine. i think it has to do with the ecu that came with the engine. the ecu is tuned for bigger injectors, and I am leaning out, i am not sure... guess i should open up the ecu and see if there is a rom in there.
float_6969
also check for boost leaks/vaccuum leaks.
Foreva180
the boost leak has to be pretty major for the car to hesitate pretty bad right???? there is a dent on my sidemount, but i listened to it closedly and it doesn't seem to leak =\
float_6969
not really. don't forget to check everything on the suction side of the turbo too.
Foreva180
good point! i'll check that for sure. think it might be the ecu though??? also, on the passenger side of the engine, there are 4 vaccum connections. i know one which is the very top one is for fpr, what about the rest of the 3?? and if you could name them in order from top down. thanks!
USDM_OneVia
Car: Racing
Foreva180 wrote:the boost leak has to be pretty major for the car to hesitate pretty bad right???? there is a dent on my sidemount, but i listened to it closedly and it doesn't seem to leak =\
I didn't have the FICV tightened back down enough and the car ran like absolute *** until I snugged up the other 2 bolts. It would only boost to about 4 pounds. But now I got it as high as 9 and chickened out since I am still breaking in the new clutch. So even just a small vacuum/boost leak will affect the performance in a dramatic way.
Joe
Foreva180
sorry to be knowledgeless but what's FICV stands for? thanks!
nab911
Car: 93 Nissan 240SX SE
Fast intake canuter valve ;)
Foreva180
where is that located at and what does it look like?? thanks!
