rough idle / hesitation....especially in reverse
satdog75
Car: 1993 Maxima GXE (Vin Code H)
Here's my dilemma....When the car is idling, it is a little rough but nothing serious. Acceleration is good with no missing. When the car is put in reverse, it worsens to the point that there is a "shimmy". I have ran down ecu codes, to find none (all diag levels 1-5). I have removed the IAC, cleaned, reistalled, and readjusted. I have removed the EGR valve, cleaned, reinstalled, and tested. I have checked timing (15 btdc). replaced all plugs with NGK, wires replaced with Bosch Platinum (damn those cost over $100), replaced the cap and rotor with standard. Ive run BG44K through tank twice. Seafoamed the intake. Finally sprayed all vaccum lines with throttle body cleaner to see if there is a leak, none. Oh, Ive also used a stethascope to check fuel injectors and all are ticking away.Damn this is becoming the 7th circle of hell. Anyone have any thoughts on it. I think im left with new injectors and ecu, but damn expensive and difficult, so i dont want ot do it if not needed.
forgot...did a power balance test on plugs...all good. havent done it on injectors since they are so tough to get to, i fear damaging the connector trying to get them off.
swartztech
Car: 1995 Nissan 240sx w/ S14 SR20DET
Manual or Automatic? if it is manual, is it acting up when u let off the clutch or when your on the clutch or both?
satdog75
its an automatic. I spoke to a mechanic that suggested it may be the fuel pressure regulator. question is.....where is it? i have followed the fuel line to the rails but did not locate the regulator. Can this actually be the cause. He suggested it since the car only idles rough / hesitates after it has warmed up for a couple minutes.
PapaSmurf2k3
Site Admin
if it only does it after being warmed up for a couple minutes, I'd look into the coolant temp sensor. Fuel pressure regulators rarely go bad.
satdog75
instead of bothering testing it, ill just go pick one up since they are 16.99 at Oreilly. there are 2 of them though. One with a dual wire plug and one opposite with a single wire. I am guessing the dual wire one is what i am after and the single wire is for the gauge.....is that correct? my haynes manual isnt very clear on it.
PapaSmurf2k3
Site Admin
That is correct!
