streetspirit7 »
https://forums.nicoclub.com/streetspirit7-u14716.html
Mon Jun 28, 2010 12:53 pm
Ok, I swapped the injector with another one I had lying around and that did not help. I swapped the plug and wire with the #3 cylinder that did not help. I took the plug out, grounded it and started the car, it sparked, so I have spark. Not really sure how to tell if the injector is working properly though. To make the problem even more weird, I hooked my multi meter to my plug wire to check RPMs. I was at around 780, then I pulled the injector plug and dropped to around 690, plug it back in and back up to 780. Then I pulled the plug wire out, there was no change in my idle. Does that make any sense to anyone?
