Nunook »
https://forums.nicoclub.com/nunook-u19785.html
Wed Apr 11, 2007 5:07 pm
I also have alittle rough idle and planned on trying to clean it up tomorrow. I have so far tried to increase fuel alittle at 500rpm on fuel map. Didn't do anygood.I also took my coilpack harness out and changed the 1 wire that grounds all 4 coilpacks to the back of the head. I made it into 2 wires and alittle thicker gauge(wanted to do this for a while). barely helped and tedious work. Tomorrow Im goin to hook up the romulator and work on it alittle. In my case Im pretty sure its fuel related. If I press on the accelerator just enough to get the rpms up to ~950-1K, it clears up. Maybe ill just adjust the screw on the throttle body?
