hugotv »
https://forums.nicoclub.com/hugotv-u2133.html
Sun Mar 13, 2005 2:17 pm
I'm experiencing the exact same problem with 91 240sx. Same thing with turnin lights and wheel, which lowers the rpm substantially to a point where the engine just stalls. Now I have to brake and slightly keep the tip of the foot on the gas to rev the engine so that it doesnt stall on the road, or worse, when going off the curb on the highway. I think by this time I've mastered the heel and toe braking technique you'd see racers do when engine braking ;-) It sux and it seems to get worse when you increase the fan to the highest setting, and see that rpm drop to 400 rpm. When I pop the hood, the engine seems to give a hissing noise as if strugling, the sound seem to be coming out of where the block is and somewhere maybe from the injector area. Would be great if I had a hidden turbo there somewhere It gives that hissing noise only when rpm lowers. Could be injectors? Maybe. Howver I've just done an ECU check, and it seems that I have a foul O2 sensor, since when I run the engine in Mode2, the red LED doesn't blink for more than 5 times during 10 seconds as described in FAQ section, rather the red LED is completely red for about 20 seconds, then it is off for no more than 5 seconds, and it goes completely red again for 20 seconds. I suppose that is the exhaust gas sensor problem, as described in the FAQ section, because for the self diagnositc mode it gives a 55 code, which means no other potential problems present. Did u perform ur ECU check, 180sxpanda?
