Wayside »
https://forums.nicoclub.com/wayside-u95030.html
Fri Jul 15, 2011 4:17 pm
Okay, so I just got done dropping in my freshly built CA18DET and now I'm having some issues with it. Upon first startup it ran just fine and idled good too. I Installed an SAFC II and now it will startup normal, but after running for roughly a minute it starts to stumble. You can give it throttle on initial startup and it doesn't hesitiate, but after it has warmed up a bit the rpms start to jump up and down 100-300. Eventually it starts stumbling and under throttle it misfires. Idling it starts to act like its not getting enough fuel then will eventually die.
Naturally my first thought was that the SAFC was causing the issue, so I clipped the power wire to see if it would run normally again, but it does not!
My question is whether the SAFC could still be affecting the engine with the power wire disconnected? I noticed that after I hooked it back up, it remembered the settings I programmed it for. The only settings I changed were for initial setup:
Sensor Type: Hot Wire (arrow up)
7 in 7 out (stock MAF)
Mods (of importance):
CP 9.5:1 Pistons 83.5mm
Cometic Gasket set
T3 Turbo
FMIC
440cc GTR Injectors
Blitz Access ECU
SAFC II
New Plugs
Fresh Oil and filter (10w30)
If it matters, I don't have an O2 sensor or exhaust hooked up at the moment..
