jason81 »
https://forums.nicoclub.com/jason81-u177690.html
Sun Jan 23, 2011 5:07 pm
Hello I have a 94 q45. I have had this car about 6 months now, when i bought it was not running right. I had pulled a code of the computer that "bad injectors" so I had 3 of the injectors replaced. That seem to fix most of all my problems but the car would sometime die as soon as it would start or sometime when i would pull up to a stop light. Anyways about a month ago a new problem started. I would drive the car an it would run perfect, but then after about 15 minutes of driving, when the car would warm up to its normal temp, the car starts shaking. The more i push on the gas the more it shakes. I am not getting a check engine light either. When the car starts doing this it seem like it has no power and dosnt seem to want to shift correctly. I think the problem is getting worse, because now it is acting this was as soon as i start it. Oh yeah, also sometimes when i go to accelerate i hear a misfire/backfire from inside the motor. Please someone out the give me some advice, I want to get my Q back to normal. I have tried running some lucas injector clean through it, some "heat" to rule out water in the gas, replaced the fuel filter, disconnected the battery to reset the computer. I am thinking maybe it could be a coil, knock sensors, vacuum line, or ? I am not getting any kind message or check engine light, can someone please help me out, Thanks
