As Ace mentions, there are steps to the process in order to accurately find the problem or even not be completely wasting time, so be sure to use the fsm and it's tests to solve your issue...or be ready to waste lots and lots of time, get nowhere and be really, REALLY frustrated and maybe do something you shouldn't do...NotSquidward wrote: ↑Thu Aug 09, 2018 10:35 amSorry it took so long to respond but the idle does bounce slightly, on start up it starts idling around 1000 rpm and then drops while twit himg all the way down. I also think your right about an air leak because it sounds like it's not getting the right amount of air but I haven't checked for vacuum leaks yet
Thanks for all the help I changed some vacuum lines and that seemed to do the trick. car is in decent running condition nowDCaff300ZX wrote: ↑Sat Aug 11, 2018 6:03 amAs Ace mentions, there are steps to the process in order to accurately find the problem or even not be completely wasting time, so be sure to use the fsm and it's tests to solve your issue...or be ready to waste lots and lots of time, get nowhere and be really, REALLY frustrated and maybe do something you shouldn't do...NotSquidward wrote: ↑Thu Aug 09, 2018 10:35 amSorry it took so long to respond but the idle does bounce slightly, on start up it starts idling around 1000 rpm and then drops while twit himg all the way down. I also think your right about an air leak because it sounds like it's not getting the right amount of air but I haven't checked for vacuum leaks yet
