NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Oct 19, 2003 6:05 am
check your wiring harness to the air flow meter. also check for a good ground to the air flow meter use a volt meter and check the ground wire on the air flow meter place the positive probe of the meter on the gnd wire and place the neg. lead on the cyl head you should see less then .02volts if it is any higher then that you need to run an alternate ground off the air flow meter to the ground wires mounted on your intake manifold. splice it in parellel with the existing wire do not cut the existing wire.
