dhen »
https://forums.nicoclub.com/dhen-u100551.html
Thu Mar 08, 2012 8:09 pm
OK, I think I might have solved this.
Before I go on, I disconnected the battery overnight and the car ran better the next day. Weird.
Anyway, according to my timing light, my timing is retarded by a tooth on the sprocket on the crankshaft. The thing is, I am 100% sure that I had the lines on the timing belt lined up with the dots on the gears/sprocket. The sprocket was loose and I jammed a shim between the sprocket key and the crankshaft. (My machinist said that this should work. The alternative is a new crank.) Is it possible that this threw the sprocket a tooth or so off center, or is that just wishful thinking?
I'll mess with it more this weekend.
PS I got a loaner compression checker from Auto Zone. It said I have 95 compression across the board. The last time I checked it, about 3 months ago, it was 155 across the board. I've barely driven it since my first check, and it seems weird to me that all the valves would go bad in exactly the same way, so I think I just got a crappy checker. Either that, or I have a seriously fycked engine.
