DaveJ-I30 wrote:mt,
Thanks for the correction. My Bro's performed the diagnostic sequence per your instructions and the code was 45, leaky injector. Now we've already replaced 2 injectors, the 2nd one yesterday and it still idles like ****. Should we replace them all ? Dam things are $80 each.
Thanks,Dave
That's interesting... that must be a California car as I'm pretty sure code 45 was only California models only.
Anyway... first thing I would do is check to see if all of the injectors are opening. You can apply 12 volts to each injector and listen for each of them to click or listening to each injector with a long screw driving or similar for the clicks. You can also check the resistance of each injector to make sure they're within specs (look for between 12 and 14 ohm).
If that pans out ok then I would bet that fuel could be leaking past one of the o-rings, especially since the injectors have been replaced as it is very easy to not get them seated properly. If one is leaking past the o-rings, just pull that injector, make sure the o-ring isn't torn or damaged, and if it is ok lightly lube the o-rings before putting the injector in to help it seat properly.
sweet3rdgen wrote:Have you checked the MAF?
MAF issues will usually throw a check engine light and a code so its not likely the MAF, plus a fuel leak like what the ECU is saying is happening would most definitely cause the issues he's seeing. I actually had an injector o-ring leak so bad once that the engine actually hydro locked and filled a couple cylinders as well as the intake manifold with fuel. Overnight all of it drained to the oil pan and turned the once 10W30 oil into the viscosity of water.
DaveJ-I30 wrote:Sweet3rdgen,
Forgive my ignorance but what does MAF stand for ?
Thanks,
Dave
Mass Air Flow sensor. Also know as:
MAFS - same as above with the SAFM - air flow meterMass Air Meteretc.
