dickie »
https://forums.nicoclub.com/dickie-u32299.html
Thu Feb 01, 2007 6:43 am
the iacv is the canister-like unit on the back of the intake manifold. find your idle adjustment screw (you can see it by looking into the engine back in the area described above), and youve found the iacv unit. get out your 10mm open end wrench and pull it off and clean it w carb cleaner.
check your grounds, theres a thin ribbon type cable connecting the back of the valve cover to the firewall and the obvious black battery ground cable. the resistance between the neg bat terminal and an unpainted sport on hte cars chassis should be <.3 ohms iirc. autozone might have the equip to check this for you if you dont.
check your plugs and wires, you may need a tune-up.
are you missing on a cylinder or is it just rough overall?
