rough engine off
Bigrolla
engine shakes like for a second or less right when u turn it off.Any ideas or anyone seen this beffore. Also my timing is at 18 which would be retarded 2 degrees i think.Engine runs great tho so its not really a big issue for me.
24_4life
some body told me once that bad gas will cause that. Something to the extent that it is knocking after the motor is turned of. Get some different gas or try an adative and it keeps happening then you might want to mess with the timming. I am not really sure, I am just taking a stab in the dark.
Texas240
Car: '89 coupe, 90k. w/ agx's & h-tech's. K&N. & cat-back
ISO HEET will take care of bad gas,timing should be at 20degrees. (i might not remember that right. but it's in the fourms or 240sx.org's faq)
p00t
i think this is fairly common with KAs.... when i put in a fidanza lightweight flywheel and new engine mounts the "problem" dissapeared.
twiztidkilla
Car: 1990 Nissan 240sx SE
its most definatly your timing... ive got an 89 toyota pickup that does the same thing...
