Koenigsegg.com on their twin Rotex SCed CCXR wrote:The Bi-compressor Centrifugal Supercharging System features twin parallel mounted Rotrex compressors, which cooperate in generating the 1.4 bar boost pressure needed to create the colossal 806 Hp output. The innovative Danish Rotrex compressor represents the next generation of centrifugal superchargers; they exhibit a higher energy-efficiency level than any other, they are operational at higher RPM levels and also feature a new and completely silent ball bearing planetary drive system.
Due to its 80% energy-efficiency, the amount of energy consumed by the compressor is returned with both a quicker and greater build-up of air pressure. The general difference when compared to alternative supercharging systems is about 10 % in efficiency, however the increase in the low end of the rev band is even greater, putting the boost pressure of the Rotrex compressor above that of any screw compressor in the RPM range of interest to performance driving. Also the very high RPM capability (120 000 RPM) of the Rotrex turbine itself allows for an extremely high maximum air pressure very early in the rev band (1.4 bar at 5000 RPM), in all creating a spread of power and torque across the rev band unmatched by any competitor.
Koenigsegg’s engineers choose to equip the CCR with a dual set of specially adopted smaller Rotrex compressors, for several good reasons. First and foremost; a smaller compressor is operational at a broader RPM range, bringing greater boost pressure at both low and high revs. This is due to complex aerodynamics around the turbine; at low RPM a greater boost is obtained since fewer pockets of air is allowed to slip through unpacked by the rotor blades. At the high rev end the smaller diameter of the rotor blades brings down the speed at which the tips of the blades collides with the air, a speed that cannot be allowed to reach near speed of sound, at which efficient compression is no longer possible.
Using twin parallel Rotrex compressors means a doubling of these small size benefits; double the effect of low rev pressure, double the quantity of air that is propelled into the intercooler at any given point during acceleration, and also a far greater maximum boost pressure. The loss of energy suffered by pulling an extra compressor is minimal, amounting to less than 1.5 % of the total kinetic energy.
Though equal in size and weight to traditional turbo chargers, the twin Rotrex compressor lay-out, combined with the innovative Koenigsegg Response Boost Control (RBC) system, creates a model for supercharging with equal efficiency to any exhaust driven turbo configuration, and that with absolutely zero throttling lag time.
ARTICLES:HOTROD:The Rotrex Supercharger Revolution
PDFs:Rotrex C30: Super Charger Technical Specs Sheet (PDF)Rotrex Super Charger Info (PDF)Rotrex C-Type: Super Charger Install and Maintenance (PDF)
Modified by rcabrita at 11:49 PM 4/3/2009
