rotors
luaq
Car: '91 240sx hb
is it possible for rotors to become too thin to still use or even thin/wear out at all?
E7-S14
Car: ess 14 foo!
too thin = weakweak= crackcrack = bad
AZ89two4Tsx
Are you talking about the rotors or pads? And grammer pwns you btw.
luaq
Car: '91 240sx hb
E7-S14 wrote:too thin = weakweak= crackcrack = bad
I see. So it is possible for the rotors to thin.
AZ89two4Tsx wrote:Are you talking about the rotors or pads? And grammer pwns you btw.
Well, the thread title says "rotors" so I wonder..
And spelling pwns you btw.
E7-S14
Car: ess 14 foo!
yeahsaw it happen to a honda accord.we tried to tap it off the hub with a hammer and it shattered.
and on my car up front the outside disk was half the width it should be.
if yours are thin.replace them. its not safe.
when pads wear. or if you constantly run pads with abrasive materials it could wear down your rotors
AZ89two4Tsx
HAHA, I spelled grammar wrong!
Anyways, I'm just used to threads like this because they usually turn out to be pointless. But yeah, replace them if they're getting noticeably thin. Welcome to NICO btw.
BrianHarte
Car: 180sx
They probably even have the minimum thickness stamped into the rotor somewhere.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
They can become too thin also if they have been turned (machined) before.
