gpelite »
https://forums.nicoclub.com/gpelite-u31517.html
Tue Nov 14, 2006 12:19 pm
I redid my brake system when I bought my car, front calipers were frozen and rotors destroyed. I went with turbo grade calipers from Nissan along with drilled and slotted rotors. I got all four done and the response is very nice. If your rotors is all you need you can get OEM fitting packages from nissan specialty sites and even ebay pretty cheap. Make sure you know the size of your rotors since earlier models have different sizes as I found out on my 1990. Luckily I had to buy new calipers anway so I bought the late model calipers to fit the larger front rotors. Make sure...
Mine are 2 years old now and its probably the most noticible mod people comment on (rest of car is OEM body wise). I would go drilled and slotted or just slotted. Since the price difference between these are nearly non existant unless you are racing professionally go all out, buy drilled and slotted.
If you want pics, I have some just let me know. I plan to paint the calipers soon to really get the rotors some attention
