rotors
s13kouki
Car: 1989 240sx
hey guys. im new here and i know ill probably get FLAMED ( Whatever that means) but anyways, im in the process of buying a house and i dont really have the money for getting a big brake kit from companys or even the 300zx one either so my question is can you get a bigger rotor and still use it on the stock brake caliper, some of you might ask why would you do that instead of getting the calipers first but like i said i dont have the money right now. In case anyone wants to know i was looking at the project mu's but if anyone else out there has any other advice which i know yall do please let me know thanks and again sorry for the stupid question.
PS can someone please tell me what flame means.
corn322
Car: 1993 240sx
I'm pretty sure you can not use a bigger rotor with the stock caliper, because it probably won't fit in the caliper.
also, you can get brakes off a q45, they work just as well.
chmercer
you could use a larger rotor with the stock caliper if you made a bracket to move the caliper further away from the center of the hub, but it would be retarded and probably cost more than a good setup.
if you dont have money, then why the hell do you want to buy project mu rotors. my whole z32 brake setup cost less than a pair of project mu rotors.
InsanityInc
I've never understood the point of buying expensive rotors. Spend it on the pads instead, they make a much larger difference.
SmithSR
Car: 240sx
^^True.
Assuming rotors are in serviceable condition.Lots of rotors I see on people's cars are worn down near minimum spec.
