Rotora brake kit question...
A Paratrooper's 300zx
Car: White 92 300zxTT M/T, Silver 04 MR2 Spyder M/T
i currently have Motegi DP10 18'' wheels on my Z and i am looking to get the 6 pot Rotora 14'' front brake kit. i am wondering if that large of a rotor and caliper system would fit behind those wheels? i know it says a minimum of 18'' wheels are required, but seeing as how im in afghan right now and cant do the actual measurements myself, i would like to know what y'all think. i dont want to buy the kit and get home only to have it not fit behind my wheels. also, is 6 pot really worth the extra size/stopping power/money? or would 4 pot do just fine? any info would be much appreciated, thanks.
Moszczyensky
Car: 1994 Nissan 300zxtt
4 pot is probably ok, but if you really want a ton of stopping power and have the cash go for the 6 pot dont skimp on brakes, especially if you are going to be racing on a track.
[email protected]
Car: 93 Nissan 300ZX NA
Moszczyensky is right, 4 pot is probably good enough, and you defiantly do NOT want to cheat your self on brakes. That being said, I haven’t heard too many good things about Rotora products. You might reconsider your choice of brake manufacturer.
thanks for the input Jai, being that you work for a brake company, what system(s) would you recommend?
SilverTwin
Car: '91 300ZX TT
I did quite a bit of research earlier this year and decided to go with StopTech's. One of the many +'s with StopTech is that they use the same pads as the Porsche big red calipers so your pad options are almost endless.
Here's a comparison to stock rotors/calipers, this is the StopTech 4 piston 13" kit, they also offer a 14" kit with matching rears as well.
And a bad quality picture from the night that I installed them
As Jai stated, when you really start digging beyond people looking for cosmetic brake upgrades, the Rotora's don't rate nearly as high as many other options on the market.
MiiLaNo
Car: 90 TTZ, 96 NA Slicktop, 01 M3
Silvertwin, that is some nice brake kit! just wanted to give you props for it! not to even mention the rims!
RemixZ
Car: 2003 350z Touring & 1990 300zx NA, Past Sold 1991 NX2000 & 1999 Frontier King Cab
Ahhh is it me or do the rotors look like they are on the wrong side? nice though
SilverTwin
Car: '91 300ZX TT
DaturaZ wrote:Ahhh is it me or do the rotors look like they are on the wrong side? nice though
They are installed properly, unlike most of the generic Brembo style rotors the StopTech's are a true directional vane design.
From StopTech's site:
"The StopTech AeroRotors® are directional. If they are not installed on the proper side of the vehicle, airflow will be restricted and cooling will be severely diminished. The vanes on a rotor act like a centrifugal air fan, drawing air from the inside of the rotor and flowing it to the outside. The vanes of a directional rotor should arch back like arms on a pinwheel. On the top side of the rotor, the vanes should curve toward the back of the car.
(Driver's perspective looking forward)
The slots on StopTech AeroRotors are cut in the OPPOSITE direction of the vanes. The pattern on a drilled AeroRotor also has the same appearance. The direction of the slots or hole pattern should not be used to determine what side of the vehicle to place a rotor. Different manufacturers may have different strategies for slot and hole patterns. "
