Rotor upgrade question
offtheline
So here is my deal. I eventually want to upgrade fully to the Z32 brake setup, but right now I just dont have the 850 bucks to buy the whole kit. However, my rear brakes are in bad shape so I wanted to buy all new rotors and brake pads for the car and use the stock calipers up front. I need the rotors that I buy to be used with the z32 calipers later on. I know there are issues with the 26mm and 30mm but does anyone know if the rotors from the upgrade kits will work with the stock calipers? Or does anyone have any better suggestions?
Exar-Kun
Car: 2005 350Z
the upgraded Z32 rotors will not work with your stock calipers...
if you dont "need" front rotors, just repalce the rears and save up money for the brake upgrade later.-chet
