rotor question???
j30t
I am looking to get new rotors for my J and was wondering if 240sx 5-lug rotors will fit my J. Also I was wondering if there is any difference between the 240sx rotors and the rotors made for the Q/J. Here is the auction I am looking at http://cgi.ebay.com/ebaymotors...3564.
Q45tech
The 240sx rotors will not work on J30!
j30t
why wont the 5 lug ones fit my J?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
j30t wrote:why wont the 5 lug ones fit my J?
Why would you want to but rotors designed for a 500lb. lighter car on a J?
j30t
good point...thanks....should i just buy Q rotors?
Q45tech
Rotors have to be the correct diameter and thickness to fit the calipers...........the rears are not interchangable on the J or Q EITHER.
Eswift
Car: should be obvious enough
go to http://www.NOPI.com and buy any of the rotors they have. they will fit. they arent that expensive.
JBJ858
i have a rotor question..i have a 93 240sx coupe...i was planning on getting brembo slotted cross drilled rotors for 200 for all four...what are my advantages and disadvantages with these rotors compared to the stock ones....please respond..
Eswift
brembo doesnt cross drill their own rotors.
Q451990
If they're drilled and slotted correctly, they should last longer between resurfacing (warp less easily). Like Eswift mentioned, the drilling isn't done by Brembo. The only major supplier that I've found that drills their own brakes is Autospecialty PowerStop. I've been told they use Bradi or Brembo blanks for the process. Just be sure you avoid rotors from some guy in his back yard with a cold beer and a drill press.
Heath
Eswift
not that a cold beer and a drill press arent cool... they just dont mix with a rotor that should be CNC machined.
personally, im fine with CNC machining and beer hand-in-hand. (as long as the G code is compiled ahead of time)
Q451990
Cold beer and tools are great... but only when I use them :)
