Anyone have an idea of what the issue can be?
I have the BrakeMotive drilled and slotted rotors and brake pads from ebay....
Thanks in advance guys any input would be appreciated.
Resurfacing drilled or slotted rotors is possible, but expensive - the lathe must be run at much slower speeds to prevent problems with cracking, etc. Not all shops will want to do it!svard75 wrote:Plus how were you expecting to refinish them once the pads wore out?
Yeah, the sound of slotted or drilled rotors are quite different from plain old iron rotors - some effect of the pads sliding over the removed material spots, I guess. Pitch changes as the speed changes too.vasekvi wrote:But even if the rotors didn't crack they still made a humming sound during medium effort braking.
