S14-KOUKI-MONSTER »
https://forums.nicoclub.com/s14-kouki-monster-u39701.html
Thu Sep 13, 2007 12:27 am
The bleed nipple should be pointing up on each side, pointing down is wrong.Just checked your pic, and the calipers are right at the top of the rotor which will most likely make them hard to bleed while still bolted to the bracket. If so, unbolt from bracket, and slide caliper(with rotor still between pads in caliper) to where nipple will point up so you can get all the air out. Then re-bolt to bracket.
Not sure what you mean about adjusting the piston on the caliper. You will either have to turn/thread the piston back inti the caliper body, or push it in depending on the design. Not sure about maxima brakes.
