Well so much for checking over the weekend...
I finally got under the car today - went in from the front side first - no sign of anything unusual.
Went in from the rear (ooh err Mrs!) and didn't see anything unusual at all - looked at the carrier bearing - it appeared as it should when it left the factory to be honest.
I then ran my hands round the drive-shaft (ooh err Mrs! x 2) closest to the diff. I noticed that there was a slight projection that interfered very slightly with the hand-brake cable..which in turn transfers the impact to the metal shielding under the car...hmmm.
So in summary the driveshaft was basically turning and whacking the handbrake cable making a heck of a weird noise.
I've pushed the cable back (roughly) into position but couldn't get one run exactly into the correct position for the provided clip. That will be tackled another day of course.
I read numerous posts about people having problems after removing the rear ends - I'm wondering now if it was simply the handbrake cables that were the problem for most folks as it's not really that obvious from underneath?
This problem resulted when I had the gas tank swapped due to a crack on the passenger side. The guys obviously didn't do a thorough job on reassembly, as I've already fixed a disconnected fule tank hose that gave wildly fluctuating gas gauge readings and an exhaust hanger did not have the pipe on it!
Overall, I'm bloody relieved it wasn't anything worn out or damaged as this car has been very well looked after in the 12 years that we've had it
