I have a goal now then. If a little honda 1.8 can make thos numbers na I think I can make that on a ka no prob. Go with about 12:1compression and the right valvetrain I kno it can and has been doneRazi wrote:300-400hp on a N/A KA engine is impossible.Do more research.
200hp has been the max for a N/A KA, and the two engines have more differenences than their displacement.But it's your money, just don't feel too bummed when your "400hp NA build" barely makes 200hp.dsm turned nismo wrote:
im running 13:1 NA with a fully built forged everything stage 3 BC cams 272's duel springs..blah blah..you wont get past 225hp to the wheels NA...trust me..ive tryed everything to break that with no luck and lots of wasted cash...turbo is the way to go..some head studs..new pistons and 12 psi..your close to 300hp just like that.dsm turned nismo wrote:
if your looking best bang for the buck go turbo or spray. N/A builds on a 4cy get very exspensive if done rightdsm turned nismo wrote:I'm looking for the best "bang for the buck" rotating assembly. Like pistons rods bearings. Cheap but decent. Looking for 300-400 hp na
im not gona flame ya dude..as you obviously havent tryed to build a KA ...even with the BC stroker kit..or even the allmighty on your side can you make 300hp NA out of a KA...if you think this is possible....show us the numbers..and how it was done..so the rest of us can copy your holyness and make our money pits 300whp NA...prove it..or retract thine statement sire!EgoManiac77 wrote:quick question what grade fuel and sized injectors do u run bc if u are not making 300hp on built 13:1 compression and race gas (witch u have to have with that compression without knocking at very least E85) u or your tuner is doing something wrong. it also sounds like u haven't tried the BC stroker kit. however i do think turbo is the way to go to make power u guys need to step back and think before u tell some something cant be done if u havent explored all ur options. good luck with ur build and welcome to nico dsm turned nismo
tell me this then what is it about the ka that is so na power limiting?gumby74 wrote:You obviously don't know enough about engines let alone THESE engines in specific to consider such an unrealistic feat as nothing more than a "goal". You have neither the resources, nor the finances to make it happen with a KA.
Best realistic option would be an Autech SR20 with ITB, and some additional work. Even with the Tomei stroker kit and ITB's that engine will still not break 275. JUN has not had much success in that department either.
Now on the other hand if you are intent on staying atmo with a four banger (make no mistake, I respect that greatly as I am an n/a man myself) consider the S2k powerplant. And don't go getting all offended, try and understand that when I speak, I speak in general terms. It is not even a consideration to boost egos any more than to insult or hurt feelings.
Where to begin? First, let's begin with the most obvious factor. This engine was primarily engineered as a truck, sedan and minivan engine in which low down torque, broad accessible powerband and slower engine speeds are preferable.dsm turned nismo wrote:
C'mon now, cain't we all just get along?liquid_cool wrote:nice post gumby...thats about it in a nutshell...but im still waiting for his miricle 300hp NA build to show up...lol
humm...gona have to look more into this....whats the weight of the block compared to say an RB25?gumby74 wrote:Superchargers from Nuespeed, CEC, and a few others available bolt on kits, turbocharger set-ups and all the goodies to make them worthwhile. Hell even the 1.8T and 2.0T engines are quite stout and capable of building rediculous power levels with surprising driveability and reliabilty. If any drawback to the VR6 powerplant is the unfortunate weight that comes from a cast iron block and 6 cylinders worth of rotating assembly.
haha...ya that 300hp ka NA will show up when the sun explodes..lol...gumby74 wrote:Couldn't answer that with any degree of certainty. It is however more compact lengthwise. Fron pulley to flywheel she is roughly the same length and height as a KADE, but somewhat wider because of the manifold layout. The intake plenum has 2 sections, the primary sitting just above the exhaust, followed by the runners going over the head and finally the main plenum. I have seen a few of these engines swapped into the lighter MK2 GTI's running throttle bodies and let me tell you, that is some serious power and speed generated from those little cars.
Just out of curiousity, are we chewing the fat, wasting time waiting for the 300 horsespowers KA? or maybe still working to convince him otherwise?
^^^ or an 5.0 with a turboRustspecS13 wrote:How do you expect to EVER make 300-400hp for nearly free????
Going and "acquiring" a vette engine is the only way you could possibly do that. And I hope you get caught.
i said..finding an engine next to free bud...take it into context!...i build for my team mates man..we do things on the cheep..that means reaserching and pulling parts from a junk yard..and MODIFYING them to work on our builds...RustspecS13 wrote:How do you expect to EVER make 300-400hp for nearly free????
