Here is a link, that is in this VH/VK section:zerothread/279262craigztoyz wrote:Busa, any info or leads?I grew up in El Paso for 24years, that the area of west TX you are in?
This would be my IDEAL arrangement. Great power throughout the WHOLE range, ie near full boost at 2000rpm or 6000rpm, great response, and no turbos! (before you flame-throw me, I do own a turbo car, and yes its the best way to get big hp. But crap for doing skids, and **** overall control of power and response). If I could chose 700hp NA or 700hp turbo I'd go NA:)SuperHatch wrote:There is a good chance you'll see pictures of a wipple setup on my car by the end of the year. ...
Well I've been going back and forth constantly between a whipple and a procharger... I'm really leaning towards a whipple right now. I could go centrifugal and save myself the headache of doing an intake manifold, but I still have to fab up the mounting brackets, do the plumbing, run a water/air setup, etc. etc. And then I need to get some very expensive side feed injectors...ultrapulse wrote:This would be my IDEAL arrangement. Great power throughout the WHOLE range, ie near full boost at 2000rpm or 6000rpm, great response, and no turbos! (before you flame-throw me, I do own a turbo car, and yes its the best way to get big hp. But crap for doing skids, and **** overall control of power and response). If I could chose 700hp NA or 700hp turbo I'd go NA:)
Whipple rates the 140 good for up to 20psi on a 4.6L Cobra. I think it'll be plenty big enough for a VH...mtcookson wrote:The only downside to Whipple I've noticed so far is their customer service isn't that great... they were kind of asses when I tried getting info about using one of their units on the VH. The only useful info I could get out of them was which unit to use and that was the W140-AX. If you're looking for quite a bit of power then I'd probably go one step up to the W200-AX.
Then maybe I WILL need the 200....mtcookson wrote:Yeah, I agree that you shouldn't need anything larger than the 140AX. You'd have to aiming for over 700 WHP to need a larger unit.
I had originally planned on the R230... Full-Race used to do a conversion where they modded the subframe to fit it. They don't do it anymore, now they recommend a Skyline rear. It's still an R200, but it has the larger output shafts of the R230 with the beefier axles and hubs. From what they say, most people are snapping axles and not tearing up the diffs. I plan on running the R200 Skyline diff now, but we'll see how well it does or doesn't hold up. The benefit though, is since it's an R200 I have a lot more options for gear ratios out of other diffs.mtcookson wrote:Ahh, ok. Yeah I'd say with that goal the 200AX should be the biggest you need.
What differential are you currently running? If you want to stay IRS you may consider try getting the R230 in there. With the TH400 that thing should be unbreakable, even in the 9's.
Thanks for the tip! I guess it will just come down to which I can get cheaper. The Skyline diff has a 4.08 in it stock, so if I can get the Q45 setup for less than what th skyline setup will cost me and swap the stock gear out of my S14 in, I should be in business..mtcookson wrote:90-96 Q45 R200 is the same way. R230 style flange axles and axles but in an R200 package. Has 3.538 gearing but, like you said, there are enough R200 options out there you could probably change around the ring and pinion for something else.
