rookie timing adjustment
A home for 1983–1989 300ZX owners!
GMan4030
Car: 1985 Nissan 300ZX Z31
so this is going to sound like I'm an idiot but I'm really just new to all of this.
when i went to change the valve cover gaskets i took the distributor out and did not properly put it back it took me a while to realize this but when i did and set the car to TDC it would start and then rapidly decline in RPM and die however two teeth after TDC i can get the car to start if the distributor is turned all the way to the left but if i don't center it shortly after starting it, it dies it is also burning rich at first. any idea where i need to go with this?
Best bet: Start from zero.
Pull the FSM at nissanservicemanual.com and follow the timing instructions from the very beginning...
Return to “300ZX (Z31) Forum”
