CanadianCoupe »
https://forums.nicoclub.com/canadiancoupe-u104043.html
Fri Jan 23, 2009 10:33 am
I am piecing my sound system together slowly and hope to have it all ready for install this spring. I have all my speakers and am purchasing my amps shortly, I have a lot of experience with home audio but very little with car audio. I need to know what specifically I will need to buy in terms of wiring etc.
SPEAKERS
Pioneer Premier 6.75" Component Spk (TS-D720C) - 260wPioneer Premier 6x9" Spk (TS-D902P) - 360wPioneer Premier 10" Sub (TS-W2500) - 3000w max, 800w nominal
AMPS
Pioneer Premier 4-Channel Amp (PRS-4200F) - 600w RMSPioneer Premier Mono Amp (PRS-D1200M) - 600w RMS
1. What kind of wiring/amp kit do I need? Best brand? Best place to buy?
2. I am using the stock head unit temporarily, I know these amps can run off a factory HU, but do I need to buy different wires?
3. Will my factory battery be able to handle this? Should I upgrade battery? Will I need Capacitors?
4. Will I need to (or should I) upgrade the big 3?
5. Is the mono amp powerful enough for the sub?
I know most this information is scattered around these forums, but I want some expert advice for the specific speakers/amp that I am buying. I hope to do a lot of the install myself with help from a buddy who knows about installs. I like knowing everything before I do any work so any advice will help a great deal! Thanks.
