Roof Wing help" This thing is p****ng me off"
All things Altima Coupe.
NISMOT
Car: 3.5 A/C Dark Slate
Ok wow.Window gap or not for my reinstall..... I would like to do it right this time Stillen's directions suck BALLSIt seems like if it is over the seal its not sticking to anything!! cover seal looks betterThanks Guys
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I wouldnt think it would cover the gap of the window seal.... That is there to give the window ample wiggle room and flexibility so it doesnt smash when your cars body flexes (from what I understand).
If you tried to adhere ANYTHING to a rubber that flexes, like the window seal, I would just assume that the adherent would lose its tack as the rubber flexes, and the wing would be lost on the highway.
The only way I could see it covering the gap, is if the part that adheres to the car is hidden away under the wing... like if the edge that meets the window gap, is hanging tward the hood of the car, whereas the contact patch is actually a quarter inch or so tward the rear of the car.
Whats the underside of the wing look like?
NISMOT
Here is the re-tape i added some extra.
if you need a closer pic i will post another tm
DAAN.
forget about the rest, make sure the adhesive is on glass
TittayMonstarr
thats some nifty medieval scripture you got there
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
Looking at the picture at Stillen's site shows it mounted with no gap. It looks better that way as well as it follows the body lines better that mounting it with a gap.
Pic: http://www.stillen.com/image.a...7.jpg
Hope this helps.
NISMOT
wow lol
