For the Load Warrior basket, you don't need any special hardware or anything of the sort. The basket comes with all necessary hardware and will attach beautifully to the huge crossbars of the factory roof rack (the crossbar mounts that come with the rack are made for the wider curved bars, such as the ones on your vehicle).justindeez wrote:Will I need to purchase a longer bolt kit specific to my application or does the standard mounting bracket actually fit as supplied?
Yes, this is correct. You would attach the bicycle rack to the bars of the basket. The bike racks come with mighty mounts which are made for round load bars, which is perfect for the basket. If you were to purchase/use the bicycle rack without the cargo basket, then you would specifically need to purchase different mighty mounts which are made for the wider crossbars.justindeez wrote:Also, would I not just attach the bike rack to the bars on the basket that would normally attach to a standard, round load bar?
Yeah, the locks work with the hardware that comes with the basket, so it will work for your vehicle. Post the link to the eBay page just to be sure. Here's a pic of the locks which will work with the included hardware and your car...justindeez wrote:Quick question again (thanks for the patience) : I found a good deal on a loadwarrior on ebay but the mounts are 4 locking mounts. Do those fit my huge crossbars too? Thanks.
Ok, so from the images on the auction page and their description, it looks like they aren't including the SKS Lock Cores with the locking mounts (you may want to ask the seller if they are including the cores). If they aren't included, then you will need to purchase a set of four lock cores to go in the locking mounts. A set of four SKS cores is Yakima Part #: 7204. Here's a pic of the lock cores...justindeez wrote:I went ahead and got it, turned out to be a pretty decent deal
http://cgi.ebay.com/ws/eBayISA...NX:IT
comes with cargo net and installed axe/shovel mount and 4 locking mounts. I picked up an extension over at geartrade.com for 71 bucks shipped. Thanks for the help guys - I'll put some pics up once it's on.
