Pescakl1 »
https://forums.nicoclub.com/pescakl1-u98038.html
Mon Nov 24, 2008 4:28 am
That is kinda cheap, crossbars should come with their associated hardware.
They are the same Nissan uses to control the length of the bars, so you could remove one and go to a hardware store to find 4 more.
You could try to go to the parts department of your dealer, they should give them to you or sell them for cheap.
I am not sure what is the hardware name/partnumber but here what I wrote on another forum about the torque driver to install them:
Quote »... here is what would work to get the job done:- Hexagonal screw driver head pin (Ikea style), I will say 4mm (5/32" is a little bit too small and 3/16" is too large),- Screw driver head pin Torx type T-30 should work too.[/quote]Hope this help.
