roof mount antenna. is it possible?
Post all your Nissan electronics, car audio and stereo questions here!
nismosr20det
hey guys, i'm taking my car to paint soon but i want to flush my antenna on the 95 240. i want to install the bmw style sharkfin antenna or something similar on either the roof or the rear window. has anyone done this and if so how would i go about doin it.
i'm assuming disonnect the stock antenna, reroute the wires and just connect it to the new one through a drilled hole. but i've also seen some wireless ones. not to savvy on electronics. did some searches but did not help.
benemorius
Car: s13, s13, eg, e36
Is there no antenna grid on your rear glass?
nismosr20det
it does, but what i'm tryin to do is have a new antenna put on the roof and get rid of the side mounted one. do u know if its possible to just put one in?
benemorius
I would tend to doubt it, but I don't honestly know. Why bother if you have the antenna on the rear glass? That one alone worked fine for me. It might not get good enough reception for you, but you could at least give it a try.
nismosr20det
are u saying that i can take off my antenna on the rear quarter panel, and still get good reception? there is no actual standing antenna on my rear window
benemorius
Look and see how many connections you have on the rear glass. You will have two for the defogger grid, and if you also have one more then it's for the grid antenna. If you have that then I'm suggesting that it may give you good enough reception without any other antenna.
nismosr20det
kools thanks
