roof leaks need help
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
leak thru sun roof switches, see h20 on bottom of motor where u would manually crank, drain holes r not clogged
CrimsonQ
Car: Purple People Eater
Hows your gasket/seal? also does it close flat or is it sagging?
jamesmost
gasket pretty good and it closes flat. how much r gaskets?? the gasket has a gap in the back where the rubber meets about 8mm.
qship96
Car: 1996 Infiniti Q45
rubber gasket is not the problem. pour water in channels with roof open-make sure both the front and rear drains run free to the ground,if all drains run free,most likely need major repair/replacement of components{rails/shade,etc} not cheap,as mine was done under warranty years ago,around 1000 if I recall.
Q45tech
The gasket is one continuous piece the gap is the result of the gasket failing and it separates at the stress point rear center...........fill in gap with black RTV.
Q45tech wrote:The gasket is one continuous piece the gap is the result of the gasket failing and it separates at the stress point rear center...........fill in gap with black RTV.
Exactly. Thats how I fixed the leak on my Maxima, except I used orange RTV due to a lack of concern for looks.
Q451990
But the gap is not the source of your leak. I lived with that gap on Q1 for about ten years with no ill effects... never even noticed wind noise from it...
Heath
Q45tech
And the leak occur thru what solid metal it must come around the gasket..................failure tp properly treat the runner with WURTH rubber dressing and maintain flexibility...................sure the drain are critical but not if ZERO water has gotten in!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Agreed... I clean my gasket regularly (every spring when I lube the sunroof) and use protector on it like tech said...
I had that problme on my old Q as well and cleaning the drain holes really helped.
hiQ45
Car: 1992 Q45
For what it's worth (MHO)...Likewise had a leak, sealed gap at rear of gasket (1/4" slit) with black silicone. So far no more leaks...btw, we've had about 200" of rain in the last 9 months...
jamesmost
Tech - thanks for the tip - used Black RTV and now have a perfect seal. Next big rain when car is not in garage will be the determining factor.BTY my drain holes are clean and clear.
Q451990
Q45tech wrote:And the leak occur thru what solid metal it must come around the gasket..................failure tp properly treat the runner with WURTH rubber dressing and maintain flexibility...................sure the drain are critical but not if ZERO water has gotten in!
You would know better than I would... but I was always under the impression that sunroof gaskets were mostly to keep out wind noise - not be completely water tight. With the idea that the drains and gasket would work together...
Heath
Q45tech
Every Spring...........this almost hundred dollar gasket need every 90 day care [spray wait, wipe clean and respray] as do all rubber components.............Wurth for the soft, Silicone for the harder materials.
Kind of like cleaning and treating tires...............not sure annually is enough.
