fernandoh »
https://forums.nicoclub.com/fernandoh-u153769.html
Thu Apr 15, 2010 6:39 am
Thanks. As you may have noticed, the English is not my language as well as the mechanical expression neither, specially when talking about things that may have local names. I have a Pathfinder 2003 sold in Chile in 2004, which it may represent some differences with yours. Mine is with auto climate, cruiser, LSD, Automatic, rims and is SE here . I don't want to remove the fat oval bars (2) but the three other small bars that serve to protect the roof (the size of these bars is 1"x1" aprox.). All the bars can be pushed away if you remove each end of the plastic ends of long supporting rails (same side of course). The problem was that I did several turns and the torx bolt didn't move upwards. What is this meaning?. I tought in a loosen nut going somewhere and stoped the operation. But the extreme (or end) seemed to get loose at that time and I don't know if any other bolt is present there.
