What year? Coupe? Sedan?Iamtheeggman wrote:Does anyone have a roof rack or trunk rack to sell or recommend?
qft,Sentientbydesign wrote:If I saw a G35 with a roof or trunk rack on it, I would leave the owner a nasty note...
We have a Yakima rack system with a Thule box on our 05 sedan. Highly recommend!! Last time I checked, Yakima didn't have a set up yet for the 07+ sedan
Old pic
What are you going to use it for? If for a bike I would suggest going with a receiver mounted rack instead. You could also use it for luggage as long as you kept the weight of the luggage down. I did this with one of my rigs and it worked just fine. There are reciever style hitches for the 'G', just I would not use one for a trailer.Iamtheeggman wrote:Does anyone have a roof rack or trunk rack to sell or recommend?
hahah I get it!pfarmer wrote:Second, what is up with your passenger side mirror, seems to be either too high or too low?
infinitgkid wrote:
hahah I get it!
You need to attach a ground to the unit in order to provide an anode needed. This will give you .0000000000000000001 hp and allow the unit to operate as a ion motor propelling you at high speeds to the beach.SVTCOBRA wrote:Only two questions.
The first is did you install a grounding cable to the Yakima? If not do so immediately.
No, and no issues. But, why??
