i am working on fixing a couple problems with my car so i decided to start a new tune from scratch to rule that out as a problem.
currently i modded the stock ca18det bin file using this guide
http://www.boostcruising.com/silvia/eprom.asp
i adjusted the K value for 450cc injectors and a z32 maf, i also adjusted the "void blast off time" according to their guide, as well as the boost sections (which i am not sure what that is adjusting)
i am then going to use an SAFC to do the fine fuel adjustments.
here is the bin file in question
http://members.cox.net/ceniack...f.bin
also, anyone have any suggestions on adjusting the timing maps for running 12psi of boost on an HKS GTSS turbo?
