Alteus »
https://forums.nicoclub.com/alteus-u48593.html
Mon Jan 14, 2008 7:59 pm
Hey all, I'm having a similar issue with my car. It's a stock '95 KA motor, OBD-II. I'm almost positive I've got both fuel and spark, and timing is fine, but it's still not starting. Basically, after changing my oil, the car wouldn't start. I didn't touch a single thing except for the oil filter and the drain plug for the oil pan. First time trying to start it after getting it back on the ground it cranked, started, then died. Tried it again...crank, start, die. Now it will crank endlessly and won't start, just like the first video posted. And to answer the obvious question, I used Mobil 1 10W-30 high mileage oil, no additives. My first thought was to check the plugs, so I did, and they looked normal, actually maybe a little too black, but not bad. Except for one (major) thing...the plug in cylinder number 2 was covered in oil, and I don't mean just a little bit of oil, it was soaked in oil. The bad news is I just checked compression and it turned out pretty terrible...around 90-65-85-95 in order from 1 to 4. I also tried moving the distributor around (i.e. loosening the bolts and rocking it in place) to see if that had any effect on anything and it had none whatsoever.
To reiterate, I know I have fuel because it smells like gas when it cranks, and the plugs get wet. (Maybe TOO wet---the smell of gas is strong, and for a while I thought the motor was flooded.) And I know I have spark, because I tested all four spark plug boots by arcing them against a ground (don't flame me about being dangerous lol). In addition it should be noted that the ECU had stored codes for knock sensor (P0325) and crankshaft position sensor (P0335). So what do you think, is my engine toast? I just don't understand how it could have happened just like that. It was running fine before with no big issues.
Cliff notes:
- Motor ran great before changing oil, but no oil was spilled- Got spark and fuel- Car wants to start on first crank but then dies right away- Oil on spark plug in cylinder 2- Bad compression all around and terrible in cylinder 2 - Changing position of the distributor does nothing- OBD-II scanner returned codes for knock sensor and crankshaft position sensor- Dead motor?
Edit: Going to test injectors tomorrow. Maybe some oil did spill on something and short a wire out...
Modified by Alteus at 10:10 PM 1/14/2008
