my setup has been a real pain this year.
after having random stalling issues, and not even throwing codes (except for code 11 / water temp sensor), i've replaced the CAS, WTS, power transistor, spark plugs, and O2 sensor. i drove the car out normally yesterday, and today i get 5 blocks from home and she stalls on me again.
usually, i manage to get it started back up immediately, but i've had a couple times where i had to wait till it's cool to start it again. i'm not even sure if it's running too rich or if i'm over-heating my coilpacks, or both. nobody seems to have the same problem, and the weird thing is i've searched these boards and the nissan exa boards, and gone threw the ringer with replacing parts at what seems like a random guess now.
when i started my project, i thought i had it all planned out. after all, i started purchasing parts a year before i had the car imported here. i researched what i wanted, and i liked the GT28R and people's 250-280 whp goals. i tried to follow the simplest plan, and that's get everything together and to a dyno ASAP.
but i left out a few key things.AFPR - some people were getting away with a walbro, but on the dyno, it showed that it was clearly overrunning it at high boost.
clutch - i didn't know how much tq the stocker could handle, and learned it's about 180wtq.
better intercooler piping - after 4 runs on the dyno, i was heatsoaking, even with my koyo oem replacement rad and altima fans on a thermoswitch.
oem MAFS - BAD. when you switch MAFS, reset your ecu and try to get it to the dyno if you're on an S-AFC and not a ROM tune.
S-AFC - poor tuning tool. a chipped ECU is a much better solution, and the S-AFC should only manage fine points of tuning AFR's, and not as your entire tuning mechanism.
I'll bring my car back to the dyno shortly after the FMIC piping is done. i firmly believe people should take their time with their projects, research the hell out of it, and DON'T TAKE SHORTCUTS! afterwards, some decent tuning is in order, and you'll never have to worry about your project.
Aeromotive A1000-6 FPRNismo fuel rail adapterNismo Big operating cylinder (clutch slave cylinder)Nismo clutch fork pivotZoom Stage 3 clutch and pressure plate (6 puck sprung)JUN 5.4kg lightweight flywheelBillet aluminum waterpump, alternator and power steering pullies 3" Turbo back exhaustBlitz BOV Custom Turbo Intake (chopped AEM Cold air
)Apexi S-AFC 2Walbro 255LPH fuel pumpRB26DETT MAFS (80mm)NGK spark plugs (1 heat range colder-BKR7E)440cc DSM injectorsGreddy R-SPL Type 6 FMIC kit(10"X10"X4")Greddy VVC boost controllerHKS GT2530R turbo .64 A/RKoyo OEM radDual Altima fans and ajdustable fan controllerHKS Step 1 256IN/264EX camsKA24E Throttle body
