ISUJinX »
https://forums.nicoclub.com/isujinx-u50362.html
Sun Jan 14, 2007 9:18 am
Most regulations require either 2.5 or 2.75 diameter tubing, based on weight class of the car. The thickness is determined by the type of tubing (seam welded or DOM) and material. You will need thinner tube if you go with chromoly, but that has to be annealed when you are done welding. Regular mild steel doesn't need to be annealed, but you will use thicker tubing. Chromoly is harder to weld, needs (or really really should) be TIG welded, where as the mild can be either TIG or MIG. Chromoly is a tad bit lighter - on the order of 40-50 lbs less when talking about a full 12pt. cage
As far as safety concerns, the cage specs of all sanctioning bodies will give you number of mounting points, base pad dimensions and thickness. You really don't need to go thicker than what the rule book states. They did a lot of research and testing for cage integrity to maximize safety.
