the same coupe\ fastback seatbelt mounting points are also on the convertible's frame, they just aren't used. the do luck rxb will fit.Jarret wrote:You're out of luck with the floor bar by do-luck, it ties to the seatbelt hard points on the normal cars, and since the dors hold the bottom belt mount, It's useless. The best solution is a strut tower bar!
-Jarret
hahahah i have no top either!!!!i'm askingaround florida right now to see if anyone will let me cut their s13 coupe top off; some dude told me to cut off a hatch top and make a 240 truck, it could work...slownslurious wrote:wow back from the dead!
lol for the record I called IO port like last week and they said that the vert bar drop down list option is just a generic list and they dont make a bar specifically for the vert.
But if the coupe bar works and just hits the top then I need to know that because I dont have a top. It would be cheaper for me to buy the autopower and have the rear feet or rear bracing modified than to build a custom bar. Can anyone confirm that the main hood and everything from a an autopower coupe bar does physically fit inside the vert?
also avoid those cusco "cages" like the plaque they are good for posuer value only. They won't pass tech anywhere and I seriously doubt with their heim joints that they would be much good for stiffening. They use relatively thin wall tubing as well, and at angles that make me question their ability to hold the cars weight in a roll over. The way the front bars bend around the dash, they would probably just collpase there if any real load was ever placed on them. And that would probably put you in more danger of being injured by the rollcage than it would save you from danger of being crushed in a rollover.
oh yeah. forgot i had loaded this off of my camera a while backtopless94 wrote:This is Dukeboy's vert. He's got a POWERZAMCAM 4-point roll bar (assuming that's custom made) and a front strut bar.
