Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Jun 05, 2005 4:36 pm
Ok, i've been mulling over rollbar ideas for a while, and I seem to have misplaced my notes on lengths of each section of bar.
Anyways, here's a few rough sketches i popped up in photochop to give you an idea of what the bar should look like.
In this view, you can see that the feet are near the side of the floorpan and the rear seat brace. This way you can create a bracket that utilizes the unibody and structural support structures to root the bar in place instead of just the floorpan.
In this angle, you can see that the main hoop needs to be angled backwards to clear the seat and put the feet brackets close to the unibody structure. Because the main hoop is angled backwards, the rear two feet have to be there to triangulate the main hoop. otherwise the roll bar would be useless and probably fall over.
I prefer to keep rollbar designs simple. Triangulation, but at a minimum. The rear feet shoudl be triangulated to the main hoop by two connecting bars (you can sort of see them in the 3/4 shot). Also with this design, you can squeeze the rear two feet between the rear seat and the side interior panel. Once I get access to a bar bender, I'll be retaking measurements and fabbing up the bar here in the near future.
