casperfun »
https://forums.nicoclub.com/casperfun-u146207.html
Sun Feb 24, 2019 6:30 am
Just don’t worry about a spare.
In the nearly 10 yrs I never used it for a flat.
I did need to change a tire because of a nail and on a sidewall.
And also patch a tire.
Mostly you will know if tire is low with tpms.
Most nails would slowly bleed your tires and you should be able to fix b4 ever needing a spare.
Unless you have enemies who might slash your tires (vandalizm) or think your tires may blow out on the highway, I wouldn’t worry about a spare.
I even thought about removing my spare to save weight but never did because I have a lot of exterior accessories anyways and gas is pretty cheap.
I did use the spare a few yrs ago to rotate my tires trick.
Other than that, it’s been pretty useless 100% of the time this past decade.
Personally, I forget about it.
