Rogue SPORT - CVT fluid pull using an extractor
iceflow
Car: 2018 Rogue Sport S
Has anyone pulled CVT fluid using a fluid extractor through the "charging port" and if so.....how much fluid did you pull?
Thanks. - Rogue Sport ......not Rogue.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You can do it that way. You'll probably get a tad less than you would using the drain plug, say 3-1/2 quarts. You should measure or mark the container and put back exactly the same amount you removed. Don't mess around with that, overfilling is the single most common way DIYers blow up CVT's. It only takes half a pint over to send your transmission to CVT heaven. If your transmission has any evidence of leaking (even slightly), I strongly advise you lift it up and use the leveling-plug method instead of restoring what was removed. There are numerous threads in here about how to do that.
macgiver
I'm gonna invent a plastic see thru aftermarket pan for these poor little CVT's .Pan will be one inch deeper , will have a "bubble magnifier " on the side to view CVT fluid level on ingrained hash-marks , have ready tap for aftermarket temp sensor , made from recycled hi-temp hy-tech crap plastic , we utilize a top Chinese production facility in Northern China to balance quality vs price , IF possible we put a tap for aftermarket 'float gauge' = NO Question what in your pan !! :facepalm:
VStar650CL
Technical Expert
macgiver wrote:
Sun Jan 09, 2022 9:42 pm
Then all we need to do is integrate the float reading with a 3-axis G-sensor so it will maybe be accurate on a hill. Brilliant!
:squint:
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
No flux capacitor? :bowrofl:
tedc
Car: 2025 Nissan Rogue SV
2021 Nissan Sentra SV
VStar650CL wrote:
Sun Jan 09, 2022 6:51 pm
Excellent advice!!! I find it takes just a little more time and effort vs. changing the engine oil.
macgiver
I think my Juke HAS a three axis G-sensor , can maybe integrated with that see-thru pan idea , we don't have hills here so could be a value-added option when selling WorldWide on the Interweb.
VStar650CL
Technical Expert
macgiver wrote:
Mon Jan 10, 2022 11:16 pm
It does, but trying to co-opt it will cause codes in the BSM which will prevent it coordinating the fretonators.
:poke:
macgiver
That one's waaaay out there ,,, Blows way past Uranus , and barely dodge'n Pluto...... :rotfl
VStar650CL
Technical Expert
They do say the presence of smoke up your a$$ indicates the planet has oxygen.
:lolling:
macgiver
And some say " smoke gets in your eyes " , I believe is the expression. Is when the turbo is leaking up front ??
At least these CVT's DON'T have vacuum modulators , at least those older transmission's you could save , being alerted by white smoke , and ya just put a new modulator in = transmission intact :chuckle:
p.s. I used " CVT " in this diatribe ....So ' this ground ball is just inside the third base bag '.... :lolling:
VStar650CL
Technical Expert
They only use transmodulators on Venus. Ask Marvin.
macgiver
I betcha Marvin can't miss with that Lollipop sight , and if he does - he'll catch up to you fast with those Micky Mouse shoes :biggrin:
VStar650CL
Technical Expert
Mickey isn't a Looney Toon and Marvin isn't a Disney. Stop mixing apples and universes.
Return to “Rogue Forum”
