Rogue's gear shifter
sjed
Does the gear shift light up during night driving to let you know which gear you're shifting in. When I drove my Rogue home last night, I didn't notice anything lit and am wondering whether the bulb is out.
CTRogue
I noticed that as well. The actual shifter does not light up, but the dash display shows what gear you are in.
The door lock button does not light up either.
sjed
I hadn't noticed the dashboard display. I'll check the car tonight, when the wife gets home with the Rogue to see where the gear display is on the dash. Thanks.
intoranat
Car: Nissan Rogue '08
Yeah the gear is on the dash in the Bottom Center Square. If you're on Auto I think he say "0".
But once you're doing it your self it say "1" and shifts up and down the number.
jaywhiz21
Car: 2008 Nissan Rogue Gotham Gray SL AWD
intoranat wrote:Yeah the gear is on the dash in the Bottom Center Square. If you're on Auto I think he say "0".
I thought it was an "0" at first too, but upon closer inspection, it's a "D" as in "Drive."
Return to “Rogue Forum”
